How can I set it fixed when I printing a pdf?
I'm using mplot. It's a very useful feature. I am using it well.
However, when printing a pdf, I need to specify the "paper size(Z)" value every time I print, can I set it fixed?
---------------------------🎓 Answer--------------------------- Hi, thank you for asking.
Please kindly understand, You can't set this setting to be fixed.
You will need to specify the paper size you want to use.
