RE : RE :BEDIT command
When I enter the "bedit" command, it doesn't work and displays the message "_BEDIT" command not recognized. Please try gain.' I remember it working fine with my personal CADian 2021 at hom, but it's only the 2017 version we use in the office that's behaving this way. Could it be a problem due to the version difference?
In CADian 2017, the 'bedit' command is not supported, and it is not supported until CADian 2020. (Support for 'bedit' starts from CADian 2021).
As an alternative, please try using the 'refedit' command for block editing.
Thank you
