RE : RE :ARX applications
I recently switched to CADian from AutoCAD and I frequently use LISP in my workflow. However, I having trouble loading both the DOSLib24x64.arx file and the associated LISP file simultaneously using the "ap" command. I want to load the ARX file in CADian. How can I do this?
Sorry, but currently, ARX applications are not supported in CADian.
Sorry for any inconvenience.
