RE :How to improve the quality of the exported WMF file from CADian?
I exported a portion of a CAD file as a WMF file. When I tried to import the exported WMF file into Word, I noticed that WMF files are generally known for maintaining clarity even when zoomed in. However, the WMF file exported from CADian shows distorted circles and unclear text. Is there an alternative method, or could you provide suggestions to improve the quality of the exported WMF file from CADian? Thank you.
Type "export" in the command prompt, then choose "Enhanced Windows Metafile (*.emf)" as the file format, and save it. Try importing the saved file into applications like Word or Excel to see a cleaner image. This format usually provides the best quality images when exporting from CADian.
