RE : RE :Batch output
I'm currently using the CADian 2023 classic version. The batch output command is not working. Do I need to download a separate application for it or is there something else I should be aware of?
Sorry, but batch plots or multiple outputs are not supported in the classic version. This is one of the differences between the classic and PRO versions.
If you frequently require multiple outputs, we recommend upgrading to the PRO version.
