RE : RE :How do I cut lines while using CADian?
I'm currently studying CAD for the first time.
I want to use a command for cutting lines.
Is there a specific command for that in CADian?
You can use the 'TRIM' command to cut objects.
Please feel free to reach out if you have any questions after trying out the command.
