RE : RE :Issue with point marker
I'm having an issue with a point marker appearing during work, causing a problem with the screen output. What should I do in this situation?
The symptom you inquired about is an error. After executing the 'point' command, click on 'setting', then click on the first point in the upper-left corner, and press 'OK'.
This should return everything to normal.
