RE : RE :Is there any way to transform a 3D polygon to 2D in CADian?
If you wish to convert an object with 3D polylines to 2D polylines or simple polylines,
please install and run the CADian Dream, execute the CPL command, select the desired polyline, and proceed with the conversion.
