RE : RE :About save configuration setting
Is there a way to save configuration setting in CAD without using software?
The command can be saved as a file by going to the "Express" menu, then tool > system variable editor, and using the "Save All" command.
However, there is currently an error with the import command, and it is being fixed. An update is expected soon.
Sorry for inconvenient and if you have any questions please feel free to ask us.
