RE : RE :I want to select more object than 32700
I understand about the "PROPOBJLIMIT" command, and also that setting it to 0 is not a viable option. Is there any way to unlock limitation? I aware that setting it to the maximum value of 32700 limit the selection to that number of objects. However, if I want to select more objects that this limit allows, what can I do?
We can't adjust the variable to a value higher than 32700, as both AutoCAD and CADian have the same maximum limit.
When selecting more objects than this limit, they won't appear in the properties window.
