RE : RE :Issue about DIST command
I'm currently brainstorming a solution for the issue where the DIST command in the estimation work doesn't work with multiple objects as opposed to CAD software. After drawing multiple lines, when I use the TOTALLENGTH command and select the objects, it gives me an error saying the objects are not eligible. Is there any other way to handle this? It's quite inconvenient.
Sorry for the inconvenience.
The suggestion for adding multi-object support to the DIST command has already been reported to the research department.
Regarding your inquiry about the TOTALLENGTH function, if you use it with open-ended multi-line objects, it will display the mentioned message.
