RE : RE :Inquiry about boundary creation option
During block editing, in the screenshot you've attached, it appears that AutoCAD has a "Boundary Creation" tab, which allows for the creation of boundaries. However, in CADian, there doesn't seem to be a boundary creation option, resulting in no boundary lines being generated. Is there a solution for this?
Thank you for your asking.
Please try using the "HATCHGENERATEBOUNDARY" command to see if it resolves the issue.
