RE : 3D object Overlap Inspection
I would like to inspect for overlaps after assembling 3D objects that I've created.
Does it support this feature? If yes, please provide the command.
Hello, this is CADian.
Please utilize the 3D tab - Edit - Interference function. Using this command, you can check for overlapping sections in 3D solids.
The specific command is 'interfere'.
