Dear Thomos, First of all, apologize for our delayed answer. Please refer to this below. 1. The latest patch The latest patch of CADian 2014 is revision 2.1.15 I doubt that you updated the latest patch. Please check your patch No. If not, please update the new one. 2. Pop up We have approached to AutoCAD""s functions whenever announce new version. Pop up and other functions would be almost same as AutoCAD""s. (I think the most of CADian users needs almost same as AutoCAD""s) I ask in details if you need to use any pop up function. Your request would be considered to our R&D. 3. May I ask any issue with stretch command ? Just speed issue, selection error or operation error with strech? Best regards, CADian / Intelli Korea Limited 1009, Daerung 3 Cha, Suite 448, Gashan-Dong Kumcheon-gu, Seoul, Korea. 153-772 - Tel: +82 70 4610 2340 - Fax: +82 2 2107 3286 - http://www.cadian.com
