RE : Update to CADian 2011
Hello Sir, I think you registered your CADian on Jun 5, 2009."" Now you can upgrade it to CADian 2011 through followings. If you upgrade to CADian 2011, your CADian will be executed automatically. * While upgrading, you ID and password you registered before would be asked. - Please ask to cadian@cadian.com with some information if you don""t remember it. . WE have to get your company name, your name, phone No., CADian serial No., and your physical address. And then we will notice your ID or password. Regards, CADian Helpdesk Hello Sir/Madam, Thanks to use CADian, powerful DWG-based CAD at fair prices. If you use CADian, you can get ,CADian 2011, the updated version at free. An authority code will be issued while doing registration with 2011 new version. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [1] If you have CADian 2010 Pro : 1) Please off your CADian, at first. 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2011_Patch_Eng P1_xx.exe 3) Just execute this file. It would be updated automatically if click [Next] button while executing. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [2] If you have CADian 2008 Pro or less user : 1) Window Control Panel >> Add/Remove the Program >> Remove your CADian 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2011_Eng Pro.exe . Download and execute this file. . Authority code is just same with previous one. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [3] If you are CADian ARCH or MECH user : 1) Window Control Panel >> Add/Remove the Program >> Remove your CADian 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2011_Eng Full.exe (295MB) . Download and execute this file. . Authority code is just same with previous one. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [4] If you are CADian Classic user : 1) Window Control Panel >> Add/Remove the Program >> Remove your CADian 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2010_Eng Classic.exe . Download and execute this file. . Authority code is just same with previous one. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [5] If you are CADian ""Site License"" user : Please send your information. - Organization name : - Your name : - Phone No. : - email : - Serial No. : We will send the latest of set-up file as soon as we get it. ---------------------------------------------------------------------------------------------------------------------------------------------------------- * Please refer to the attached manuals in webhard if you are interested in the Batch Plot and Excel connector. * Now, you find CADian 2011 is REAL alternative to AutoCAD in the world. If any, please feel free to contact us. help@cadian.com Paul Park / CADian Soft Limited
