Hi, I have problem with Cut and Extend function when working at different Views. I know about to change a Projection option to View (2) when I would like to extend 3dPline, Pline or Line to the boundary (for example 3dPline, Pline or Line). That option should Extend/Cut to the selectet boundary according to the curent view. Unfortunately that option is not working in CADian properly. The same drawing and method and view in ACad LT is working. Is it just me or It might be the CADian that makes that problem? If you would like I can sent that drawing that I working on. Michal
