lo Sir/Madam, Thanks to use CADian, powerful DWG-based CAD at fair prices. You can get , CADian 2011, the updated version at free. An authority code will be issued while doing registration with 2011 new version. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [1] If you have CADian 2010 Pro : 1) Please off your CADian, at first. 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2011_Patch_Eng P1_xx.exe 3) Just execute this file. It would be updated automatically if click [Next] button while executing. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [2] If you have CADian 2008 Pro or less user : 1) Window Control Panel >> Add/Remove the Program >> Remove your CADian 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2011_Eng Pro.exe . Download and execute this file. . Authority code is just same with previous one. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [3] If you are CADian ARCH or MECH user : 1) Window Control Panel >> Add/Remove the Program >> Remove your CADian 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2011_Eng Full.exe (295MB) . Download and execute this file. . Authority code is just same with previous one. ---------------------------------------------------------------------------------------------------------------------------------------------------------- [4] If you are CADian Classic user : 1) Window Control Panel >> Add/Remove the Program >> Remove your CADian 2) Comes to webhard . www.webhard.net (id : cadian / password : omega1) . File location : Guest Folder >> CADian2010_Eng Classic.exe . Download and execute this file. . Authority code is just same with previous one. ---------------------------------------------------------------------------------------------------------------------------------------------------------- * Please refer to the attached manuals in webhard if you are interested in the Batch Plot and Excel connector. * Now, you find CADian 2011 is REAL alternative to AutoCAD in the world. If any, please feel free to contact us. help@cadian.com Paul Park / CADian Soft Limited
