Hello Sir, These were reset. Now you can do to CADian 2008, again. * However No need to do this process if you install CADian 2011 instead of CADian 2008. Please refer to the below. Regards, CADian Helpdesk ----------------------------------------------------------------------------------------- Dear Sir, You can get the latest of CADian 2011 from below. Please remove current CADian at first and then install new CAD, CADian 2011. -------------------------------------------------------------------------------- [ Access this webhard ] - http://www.webhard.net/member/ ( id=cadian, password=omega1 ) - Download and install this : CADian2011_EngPro.exe -------------------------------------------------------------------------------- Thanks, CADian Soft Paul Park
