help
RE : Program compatibility with autocad
Hello srikanth, 1. You can save your dwg file at lower dwg type. 1) enter ""save as"" 2) And set to lower dwg type. (ex) AutoCAD dwg 2004/2005 or lower. 3) Now Save your drawing file. 2. You can set default dwg type 1) Select "tool"" > Options >> 2) It shows new Windows 3) Click ""Fole open and Save >> Select AutoCAD 2004/2005 or lower 4) Now yoiur dwg would be saved to lower dwg type. Thanks CADian
