RE : RE :Printing a drawing to PDF from DWG
When printing a drawing to PDF from DWG, is it not possible to adjust the paper size to match the size of the drawing by user settings?
It's possible with regular printers, but DWG to PDF doesn't allow paper size adjustments.
