RE : RE :Is it possible to join an ellipse and a straight line as a single objects?
Hi, Even when using the PE command, I'm unable to join ellipse and a straight line. So I'm reaching out for assistance.
Instead of using the PEDIT command to join, simply enter 'join' in the command line, then select the ellipse and the straight line (polyline or line). This will joint them as a single object with spline properties.
