I am beginner in CAD software. When I search for commands, I only find command related CAD in general, While there are similarities with AutoCAD, it seems that there are non-compatible commands. Could you please provide a compilation of commands and shortcut in CADian?.
Shortcuts are visible in the top menu, "express > tools > command alias editor". Please refer to that and, if any are missing, add them there or export the setting from that window using File > Export and save it as a PGP file. Open the file with Notepad, make the necessary modifications, save it, and then use "Import" to apply the changes.
