RE : RE :About Bonustool
1. The Bonustool menu bar (dropdown menu) is not visible. When checking MENULOAD, the BONUSTOOL menu is loaded, but even though the top-classic menu is in use, it is not visible in the toolbar menu. Even after unloading and reloading it in MENULOAD, it still doesn't appear.
2. The toolbar - BONUSTOOL - Bonus Tools - Area Stair Tool icon is on the screen. However, do I need to execute it once using the toolbar icon initially for the shortcut key to become functional, and does it require loading to be done once for it to be usable?
The "Warea" command for calculating area is set up to load simultaneously when you press the button for the first time.
Therefore, you need to click the icon for the first execution, and from the second time onwards, you can use the command by entering it at the bottom.
