RE : RE :How to calculate the total length in CADian?
I'm not sure how to calculate the total length for the CADian. Could you please provide instructions on how to determine the overall length?
In CADian, there is a command called 'Totallength'. By entering 'Totallength' in the command prompt and selecting the objects, you can calculate the total length. Or you can choose multiple lines at once using cross or window selection methods.
