RE : RE :How to change block insertion point in CADian?
Hello, I'm trying to change the block insertion point. In CAD, it is possible to do this using parameters in the block editor, but I'm wondering if CADian has a similar feature.
The block insertion point you inquired about can be changed using the "blockReOrgin" command.
If the given command doesn't resolve the issue, please feel free to ask again at any time.
