yellowdande
DIST command doesn't work in multiples like in CAD.
When working on an estimate, I'm figuring out a solution as the DIST command doesn't work in multiples like in CAD. After drawing multiple lines and using the TOTALLENGTH command by selecting the objects, it indicates that it's an invalid object. Is there any alternative method?
