RE : RE :Issue with the output quality of raster images.
I am experiencing issues with the output quality of raster images. I used to have no issue with image quality when extracting raster images, but in the past two weeks, I've been consistently experiencing degradation in image quality. I'm inquiring about whether this is a result of setting or a simple error.
I'm curious about the command you used to extract the raster image in CADian (eg JPGOUT, etc).
However, if you use the JPGOUT command and first enlarge the image size in CADian before extracting it as a raster image, you may get a slightly better image quality.
