bluewhale7
Issue about DIST command
I'm currently brainstorming a solution for the issue where the DIST command in the estimation work doesn't work with multiple objects as opposed to CAD software. After drawing multiple lines, when I use the TOTALLENGTH command and select the objects, it gives me an error saying the objects are not eligible. Is there any other way to handle this? It's quite inconvenient.
