RE : RE :How should I do it for this?
To export the table from a CAD drawing with an inserted Excel sheet back to an XLS file, how should I do it?
First, select the table you want to import, then explode it. Select it once more and explode it again. After that, execute the XTEXPORT command to export it to Excel.
If you have any questions please feel free to ask us!
Thank you:)
