RE : RE :Help me.
Is there a way to prevent the creation of a .bak document when saving?
Thank you for your asking.
The method to prevent the creation of .bak files is as follows: Press the "OP" key and then press "Enter" to execute the command. The Options window will appear. Go to the "Open and Save" tab. In the "File Safety Precautions" section, uncheck the option that says "Create backup copies when saving." This should prevent the creation of .bak files when saving.
