coolbreeze
pdf File Size
I've switched from using AutoCAD to CADian. Currently, when I convert drawing files to PDF using CADian,
I noticed that the file size is significantly larger compared to AutoCAD.
ex) AutoCAD = 15,521KB, CADian = 78,265KB
Could you explain the reason for such a difference?
