RE : RE :Is there a way to import an excel table into > CADian?
Hi, Thank you for asking. The command is XTIMPORT can import an excel table into CADian.
Please refer to the method below. 1. Run the command XTIMPORT in CADian. 3. Adjust the options and click Scale Area. 4. Specify an insertion point. 5. Specify the opposite corner: Specify the size of the table to be imported with the mouse.
If you have any further questions please feel free to ask us.
