Is there a way to change dimension styles in a drawing all at once?
When I change it in dimsty, it changes the dimensions, but not the dimension lines, auxiliary lines, etc.
---------------------------🎓 Answer--------------------------- Hi, Thank you for asking.
Please try running the command: DIM Run > UP > ALL.
If you have any further questions please feel free to ask us.
