RE : How can I set it fixed when I printing a pdf?
I'm using mplot. It's a very useful feature. I am using it well.
However, when printing a pdf, I need to specify the "paper size(Z)" value every time I print, can I set it fixed?
I'm using mplot. It's a very useful feature. I am using it well. However, when printing a pdf, I need to specify the "paper size(Z)" value every time I print, can I set it fixed?
Hi, thank you for asking. Please kindly understand, You can't set this setting to be fixed. You will need to specify the paper size you want to use. If you have any questions please feel free to ask us.
