Hello, this is CADian.
I will guide you on how to address this.
1.Execute the SNAP command.
2.Turn on snap, set snap spacing or: [Off(OFF)/Rotate(R)/Style(S)/Type(T)]/<10>: Enter "S" and press the Enter key.
3.[Standard(S)]/: Enter "S" and press the Enter key.
4.[Aspect ratio(A)]/Enter vertical spacing <17.3205>: Press the Enter key. Please check, and if it doesn't resolve, contact us again.
