RE : Authorizing Process
Dear Support!
Recently I wanted to install my CADian2008 software on a laptop that I intend to use for my daily work.
I don't know if I'd have to request a newer auth. code, or somehow I can make the oldar one work.
I hope you can help sort this out.
Thank you for your help in advance.
---------------------------❓ 질문---------------------------
Dear Support! Recently I wanted to install my CADian2008 software on a laptop that I intend to use for my daily work. I don't know if I'd have to request a newer auth. code, or somehow I can make the oldar one work. I hope you can help sort this out. Thank you for your help in advance.
---------------------------🎓 답변---------------------------
Sir/Madam,
Please click the link below to check the authorizing process.
https://www.cadian.com/us/cs/faq_view.asp?idx=135676&bbs=faq1_us&mode=list&cate=0&pageNo=2&keyType=&keyWord=
IntelliKorea,
Technical Support Team
