RE : VBA problem
Dear Froland,
Please try to install the VBA through following link.
* http://www.webhard.net (id=cadian / password=abc123)
- Program for English User > 2. CADian Applications > VBA7.1
* Run as administrator, install below 3 files as the order numbered
1. vba71.msi
2. vba71_1033.msi
3. vcredist_x86.exe / vcredist_x86.exe
Thank you,
CADian Soft
Dear Froland, Please try to install the VBA through following link. * http://www.webhard.net (id=cadian / password=abc123) - Program for English User > 2. CADian Applications > VBA7.1 * Run as administrator, install below 3 files as the order numbered 1. vba71.msi 2. vba71_1033.msi 3. vcredist_x86.exe / vcredist_x86.exe Thank you, CADian Soft
