FAQ · 2013.12.11
CADian VBA Sample Code - 18 [ Import Method ]
[LISP/VBA] CADian에서 VBA - 18 Import
Imports a drawing or a group of saved layer settings from a file.
RetVal = object.Import(FileName, InsertionPoint, ScaleFactor)
Object
Document
The object this method applies to.
FileName
String; input-only
The name of the file to be imported.
InsertionPoint
The 3D WCS coordinates location in the current drawing where the imported file is placed.
ScaleFactor
Double; input-only
The scale used to place the imported file.
RetVal
Object
In the case of importing a WMF file, a BlockReference object is returned. In all other cases, the return value is NULL.
