FAQ · 2019.06.16
How to change your CADian Language ?
[ How to change CADian Language ? ] 1. Run your CADian. 2. ( Pull down menu ) Tools > Options or Enter OPtions in the command line.
3. Options Dialog
① Go to Display Tab and click Set Language button. ② Select the language you want to use. ③ Click OK button in the Set Language dialog. ④ Click OK button in the Options dialog.
4. CADian language will change in next session.
5. Restart your CADian, and you can use the application with the designated language.
* Please feel free to contact us if you have any questions. - E-mail: help@cadian.com (Tech. and Business Support) - Tel : +82-70-4610-2061 [ Real time text chatting ] - Skype : daniel28471 - WhatsApp : +82-10-8912-3446 - Line : cadianbest - Kakaotalk : daniel2847 Thank you ! CADian Helpdesk
